clear ports link-flap-detection status
clear ports [port_list | all] link-flap-detection status
Description
Manually enables ports that have been disabled due to excessive link-flapping.
Syntax Description
ports Physical ports.
port_list List of ports that you want to enable that were disabled due to excessive link flapping.
all Enables all ports in the system that were disabled due to excessive link flapping.
status Enable ports currently in disabled state due to excessive link flapping.
Default
N/A
Usage
Ports that have been disabled due to excessive link flapping cannot be enabled using the enable port command. They must be enabled using the clear ports link-flap-detection status command.
The following example re-enables all ports on the switch that were disabled due to excessive link flapping:
clear ports all link-flap-detection status
This command was first available in ExtremeXOS 22.1.
Platform Availability
